Isuzu Transtron Denso, engines: 4JJ1, 4HK1, 6HK1
Andy
Stanislaw do you have any plans for this ECU. I can read / write with Piasini but can not correct checksum. KTAG reads but get checksum faults and it will not save the file.
Inside SH7055 / 93c86.
Or mayby someone can check if checksum is OK. File attached.
Thank you.
Andy
275800-2812 8973750190 1 Piasini.bin
Ссылка на комментарий
Поделиться на других сайтах
