Bruce Willis Опубликовано 7 Января 2015 Жалоба Share Опубликовано 7 Января 2015 Email to support@mmcflash.ru NOT NEED WRITE ON FORUM - NEED SEND EMAIL TO SUPPORT! 0) Number of you license (key number) 1) Information about Auto (Engine, year, transmission type, vin nimber, model etc) 2) Attach the logs located at folder "my documents" then folder "MMC flasher" files like this If you have problem reading 2023.11.05_21.05.22_Hitachi SH72531(1280k)(full,eeprom) CAN_Read.htm.gz If you have problem writing 2023.11.05_21.05.10_Hitachi SH72531(1280k)(full,eeprom) CAN_Write.htm.gz 2023.11.05 - data 21.05.10 - time Hitachi SH72531(1280k)(full,eeprom) CAN - name module Write - actions 3) Software version in the ECU and stock bin file, preferably a photo of the ECU, label, general view insiad if ECU is opened. 4) A detailed description of problem, symptoms. 1 Ссылка на комментарий Поделиться на других сайтах More sharing options...
