http://www.tactrix.com/index.php?option=com_content&view=article&id=76:what-are-pinout-and-pin-functions-of-the-openport-20&catid=39:openport-20&Itemid=41
  • The 2.5mm jack Ring and Sleeve terminals can be used to receive RS-232 data from another device. This is typically used with Innovate MTS bus compatible devices such as a wide-band oxygen sensor, or similar devices from other manufacturers.
