Опубликовано 7 Июня 2017%d л comment_21086 ve just recieved the usb dongle and the vag module...all working so i tested it today on a edc17c46...id---virtual read-all good....so i modded the original and tried to write the file...all went well.until the end...basically got Communication error--code 000A. i was using the Bosch UDS ME(d)/EDC17 (STOCK)-CAN....is this just for a stock file write back... im going to test tomorrow and use the Bosch UDS ME(d)/EDC17-CAN...is this wer im going wrong.. Also what are the SLAVE OPTIONS for. Thanks Жалоба
Опубликовано 7 Июня 2017%d л comment_21087 Send me report with all info. Slave - for slave ECU Жалоба
