Опубликовано 12 Ноября 2018%d л comment_23275 12 минут назад, Bruce Willis сказал: CVT you can read only on table What the table which you mentioned. Can you show by picture?? Жалоба
Опубликовано 12 Ноября 2018%d л comment_23278 1 час назад, Bruce Willis сказал: Show photo ECU that you need read MH8106F 851A105 U0 Жалоба
Опубликовано 13 Ноября 2018%d л comment_23280 5 часов назад, Bruce Willis сказал: the whole pcb and connectors I have only this picture. the cvt ecu already re-install to my car Жалоба
Опубликовано 15 Ноября 2018%d л comment_23295 @Bruce Willis Any suggestion, looking to solve this matter. Жалоба
Опубликовано 5 Апреля 2022%d л comment_26989 В 15/11/2018 в 20:47, Bruce Willis сказал: enviar-lhe e-mail Hi Bruce, I need to read/write Lancer EvoX AYC-ACD-SAWC MH8104F ECU Number: 8631A040. I Use MMCFlash module 03 (MH8104F [512K] K-line (test CAN too) - but not conect to module. Any idea? (Pin: 4 CAN-H; 5 CAN-L; 23-Diag Boot; 24-K-line Diag; 25 (+); 26 (-)). The CVT modules 8631A790 (MH8106F) and 8631B191 (MH8106F) i can read by MMCFlash easy. Жалоба
Опубликовано 5 Апреля 2022%d л comment_26990 03 Module used for engine, not for AYC-ACD. You need founf Kline and boot or use 71 module Жалоба
Опубликовано 8 Апреля 2022%d л comment_26993 В 05/04/2022 в 07:27, Bruce Willis сказал: 03 Módulo usado para motor, não para AYC-ACD. Você precisa do Kline e inicializar ou usar o módulo 71 Hi Bruce, i cant find the 71 module in http://mmcflash.com.ru/en. I think the module was disable by mmcflash. I read the CVT (MH8106F) - Kline by 03 module suscefull and try to read ACD in same conditions but not work (maybe the connections wrong?) You can to explain better about "founf Kline and boot"? Thanks! Жалоба
Опубликовано 8 Апреля 2022%d л comment_26994 В 05.04.2022 в 07:27, Bruce Willis сказал: 03 Module used for engine, not for AYC-ACD. You need founf Kline and boot or use 71 module I Find this in the 03 module - see the ACD in the text.. Описание Модуль 3 поддерживает чтение и запись следующих типов процессоров серии M32r используемых как в ЭБУ управления двигателем, так и ЭБУ управления активным центральным дифференциалом: MH8104F_(512к) by CAN MH8104F_(512к) by Kline (repair/восстановление) MH8106F_(1024к) by CAN MH8106F_(1024к) by Kline (repair/восстановление) ACD EVO X m32r (512к) by Kline Добавлена возможность чтения и записи кодинга, а так же чтение и запись Vin номера. Модуль способен вывести информацию о версии ПО ЭБУ, VIN номер, номер аппаратной реализации ЭБУ и пересчитать контрольную сумму. А так же восстановить кнопкой Unlock после неудачно попытки чтения/записи программой ECUFLASH. Доступен пересчет контрольной суммы. Процессоры серии M32r используемые в ЭБУ компании Mitsubishi программно восстанавливаются из любого состояния по К линии при помощи встроенного бутлоадера. При чтении/записи желательно отключать вентилятор или подсоединять зарядное устройство. Жалоба
Опубликовано 8 Апреля 2022%d л comment_26995 http://mmcflash.com.ru/ru/catalog/71-modul-mitsubishi-tcmcvtat4wdacd Жалоба
