Опубликовано 12 Февраля 2018%d л comment_22223 Stanislaw do you have any plans for this ECU. I can read / write with Piasini but can not correct checksum. KTAG reads but get checksum faults and it will not save the file. Inside SH7055 / 93c86. Or mayby someone can check if checksum is OK. File attached. Thank you. Andy 275800-2812 8973750190 1 Piasini.bin Жалоба
Опубликовано 12 Февраля 2018%d л comment_22239 You can read it 36 module on table, and checksum will be recalculate. Жалоба
Опубликовано 12 Февраля 2018%d л Автор comment_22242 Thanks Bruce, will try and report. At the moment customer picked it up to test in the car. Andy Жалоба
