Опубликовано 28 Февраля 2020%d л comment_25099 hi guys, i have mitsubishi endeavor ecu cpu MH8302F mmcflash fail to read i get this error [Adapter name] Tactrix Inc. - OpenPort 2.0 J2534 ISO / CAN / VPW / PWM [Firmware version] 1.17.4877 [Dll version] 1.01.4247 Apr 18 2014 16:14:11 [07:23:38] Engine part number: MN & 53 [07:23: 38] Engine romid: B88151 [07:23:46] AT part number: MN & 53 [07:23:46] AT romid: B64531 [Adapter name] Tactrix Inc. - OpenPort 2.0 J2534 ISO / CAN / VPW / PWM [Firmware version] 1.17.4877 [Dll version] 1.01.4247 Apr 18 2014 16:14:11 [07:23:54] Error: no response from ECU. Check contacts and additional devices on bus, such as anti-theft alarm system., Code: 011E Жалоба
Опубликовано 29 Февраля 2020%d л Автор comment_25101 thanks will send logs to email will give feedback here Жалоба
Опубликовано 4 Марта 2020%d л Автор comment_25107 hi guys, thanks for your help and support it worked. Жалоба
Опубликовано %s в %s%d дн comment_33151 Hello how did you solve the problem? Im having the same issuse. Could you help please? Жалоба
