twisteddiesel Опубликовано 30 Августа 2022 Жалоба Опубликовано 30 Августа 2022 I bought mmcflash 5884 a while back, got the software installed and updated, but the module I purchased is not active. Module 36. Can someone help me get it activated? Thanks! Цитата
Bruce Willis Опубликовано 31 Августа 2022 Жалоба Опубликовано 31 Августа 2022 Why you bought from ECUTOOLS and not activate module - write here ? May be you need write ecutools ? You have only empty key and you NEED WRITE WHERE YOU BOUGT IT (ECUTOOLS)! Цитата
twisteddiesel Опубликовано 31 Августа 2022 Автор Жалоба Опубликовано 31 Августа 2022 I wrote ECUtools and they are trying to figure it out, thank you. Цитата
