Опубликовано 12 Июля 2023%d л comment_27620 Hello, i want to read/write a Mazda 2 1.5 Skyactiv-G 75hp 2017, witch module for that? module 78? Thanks Жалоба
Опубликовано 13 Июля 2023%d л comment_27622 hi push ecu info on any ford/mazda and mmcflash say you what module- or show me idents Жалоба
Опубликовано 25 Июля 2023%d л Автор comment_27638 I see module 31 at the bottom left, I guess that's it Жалоба
Опубликовано 25 Июля 2023%d л comment_27639 В 13.07.2023 в 03:17, Bruce Willis сказал: hi push ecu info on any ford/mazda and mmcflash say you what module- or show me idents ! Жалоба
Опубликовано 25 Июля 2023%d л Автор comment_27640 i don't understant your answer, you confirm me module 31 is correct? Жалоба
Опубликовано 25 Июля 2023%d л comment_27641 I don't know why don't understand , but use brain. Push ecu info on any other ford/Mazda module and mmcflash say you right number of module. If you don't understand this simply words , use another device. Жалоба
