Is this ECU supported? I tried to read it but unknown checksum. was using open port 2.0. will direct connection work ? If so have a pin out? If it can read it will it be able to write? And where can I get a stock file from? Trying to Delete DEF DPF EGR. Thank you for your time.IMG_20230719_112110690_HDR.thumb.jpg.fac4540a139e77b5ca23d91c1467d5da.jpg
