antmartian Опубликовано 20 Июля 2023 Жалоба Опубликовано 20 Июля 2023 Is this ECU supported? I tried to read it but unknown checksum. was using open port 2.0. will direct connection work ? If so have a pin out? If it can read it will it be able to write? And where can I get a stock file from? Trying to Delete DEF DPF EGR. Thank you for your time. Цитата
CATCOL Опубликовано 6 часов назад Жалоба Опубликовано 6 часов назад Hi, im Ricardo , I have Isuzu transtron. I have a problem; this happened after I wrote a .bin file. Now i have this code and the ECU won't let me do anything or recognize it. Do you have other module to unblock this ecu? or other method? plese help me plese look the attached photos thank you so much for your help Цитата
Bruce Willis Опубликовано 1 час назад Жалоба Опубликовано 1 час назад You lost connection usb with J2534 or yours J2534 dead. Don't write in the support from @hotmail Hotmail block our emails host hotmail-com.olc.protection.outlook.com [52.***.**.**] SMTP error from remote mail server after pipelined end of data: 550 5.7.1 Unfortunately, messages from [91.***.***.*] weren't sent. Please contact your Internet service provider since part of their network is on our block list (S3150). You can also refer your provider to http://mail.live.com/mail/troubleshooting.aspx[truncated] Write from gmail. Цитата
