theodore Опубликовано 7 Января 2024 Жалоба Опубликовано 7 Января 2024 hi,what is SAFE WRITE button in module 36? and is it normal the module to recalculate checksum to the ori file?is it possible the ori file to had bad checksum but the car was running fine? Цитата
