rpsales Опубликовано 8 Декабря 2024 Жалоба Опубликовано 8 Декабря 2024 Hello all, Im using scanmatik original with MMC. I can read/write transtron ecu without problem. When I try to read FORD DCU101 I got this error: [08:50:06] Software version: 6C11-12K532-HJ [08:50:07] Calibration: 6C11-12K532-HJ [08:50:07] Hardware part number: 6C11-12B684-AB [08:50:07] Catalogue number: 6C11-12A650-AL [08:50:07] Serial number: YCQHW0AN8GHW [08:50:07] CVN: 0000AA5D [08:50:07] VIN: WF0DXXTTFD7Y13716 [08:50:26] Error: no response from ECU. Check contacts and additional devices on bus, such as anti-theft alarm system., code: 010F I can read DTC and read ECU info with scanmatik, but cannot read/write maps. Scanmatik drivers are updated and scanmatik support says this is software issue. I use tactrix and it read/writes FORD DCU101. Anyone face this problem with scanmatik device? Thank you Цитата
Bruce Willis Опубликовано 8 Декабря 2024 Жалоба Опубликовано 8 Декабря 2024 If you can read/write with open port - then problem in scanmatic Цитата
