sama13 Опубликовано 3 Апреля Жалоба Опубликовано 3 Апреля Hello, would it be possible to read this ECU which is currently "locked" by uprev tuning software to be able to take it back to stock to be able to tune it properly. Thanks in advance! Цитата
Bruce Willis Опубликовано 4 Апреля Жалоба Опубликовано 4 Апреля Hi at this time only jtag or dealer uprev back to stock. In future we will do module. Цитата
sama13 Опубликовано 4 Апреля Автор Жалоба Опубликовано 4 Апреля Thanks Bruce, Do you think it would be possible to perform immo off on another ecu and use it, flash the software to be able to make it work accordingly? The car is a race car so it already has immo off on that ecu and several other modules removed, here is the label one possible to buy not sure it works as the matching part is BEM390 Цитата
Bruce Willis Опубликовано 5 Апреля Жалоба Опубликовано 5 Апреля Yes we can do immooff , but we close reading and gave file in crypto format. Цитата
