JO AUTO TECH Опубликовано 1 час назад Жалоба Опубликовано 1 час назад hi pls help the ecu pin out of Suzuki wagon r..I want to read with mmc flash module 3 ..use flash MH8104F . Engine K6A automatic transmission. I try to use pin out from pcm flash failed.. Цитата
