Опубликовано 17 минут назад%d мин comment_33618 hello,I have problem with OBD reading ECU sim2k-141...It makes connection with ECU, ID. DTC... but when I star to read it show info that I should change protcol to sim2k-240 and then it can not do ot of course I have full backup of this ecu read with boot mode via kess... logs of reading trying via MMC...Somebody had the same problem? ECU data:HW: KR774352_C01SW: KR77435107Software version: KEC0R91CThank you for any help :) Жалоба
