the dog Опубликовано 29 Марта 2013 Жалоба Опубликовано 29 Марта 2013 I would like to flash a Mitsubishi Colt CZT ecu but I need checksum correction Is this tool up to it? What option do I need from the product package and how can I buy it? I have been trying for over 3 weeks to get in touch with evoscan but I got no response from them. I need the tool asap .Today is possible. I am from Nicosia Cyprus Цитата
Bruce Willis Опубликовано 29 Марта 2013 Жалоба Опубликовано 29 Марта 2013 Hello! What CPU in your Colt? If 8304, than it is 2 module and he can make checksum correction. Цитата
koz Опубликовано 1 Апреля 2013 Жалоба Опубликовано 1 Апреля 2013 Hello! What CPU in your Colt? If 8304, than it is 2 module and he can make checksum correction. do you have to open the ECU to find out what the CPU is ? can you deduct that from the label on the ecu ? Цитата
the dog Опубликовано 24 Апреля 2013 Автор Жалоба Опубликовано 24 Апреля 2013 I am trying to clone a stock ecu onto an identical ecu (label and serial) for testing the mmcflash. I used MH8304F to read and the read look ok. I was able to flash it to the spare ecu but when I can not get it to work on the car. I didnt do any checksum correction since i am 100% sure that the stock is fine. Maybe the file is more than 512kb? I read both ecu and compare them in hex and the 2 reads are identical Цитата
Bruce Willis Опубликовано 24 Апреля 2013 Жалоба Опубликовано 24 Апреля 2013 Where the bin file? What does not work? What error? Цитата
the dog Опубликовано 26 Апреля 2013 Автор Жалоба Опубликовано 26 Апреля 2013 The tool can write on czt without issues. There is an issue with checksum correction. On 1 CZT the checksum correction is working ok,but on another it is not... Цитата
Colt_4G15T Опубликовано 28 Февраля 2014 Жалоба Опубликовано 28 Февраля 2014 I'm from Austria and I also would like to use MMC-Flash to do a reflash of my colt czt 2005. Could somebody help me because there is no Evoscan support ?? The Evoscan instruction says that you need pin 11 and pin 7 on the obd-2 port but I only got pin 14 and pin 6... Цитата
Bruce Willis Опубликовано 28 Февраля 2014 Жалоба Опубликовано 28 Февраля 2014 Can you have a photo? Цитата
СаняЖД Опубликовано 28 Февраля 2014 Жалоба Опубликовано 28 Февраля 2014 Picture your ECU give us. And we will tell you how to connect directly to ECU. Цитата
Bruce Willis Опубликовано 1 Марта 2014 Жалоба Опубликовано 1 Марта 2014 And photo OBD connector Цитата
Colt_4G15T Опубликовано 2 Марта 2014 Жалоба Опубликовано 2 Марта 2014 Foto OBD connector: http://www.imgbox.de/show/img/dGikA47YwW.JPG http://www.imgbox.de/show/img/cxExSvQWQM.JPG Thanks!! Could you guys provide a licence for MMC-Flash?? Цитата
Colt_4G15T Опубликовано 2 Марта 2014 Жалоба Опубликовано 2 Марта 2014 ECU: Моя ссылка ECU connectors: Моя ссылка Thank you! Цитата
Bruce Willis Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 try this colt 2004-2008 Цитата
Colt_4G15T Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 Thanks!! And does this work without Mmc-flasher or do I have to buy a licence for version 2 mmc flash?? Цитата
СаняЖД Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 what version 2? there is no discussion of "version 2"! "Version 2" is a fake. The MMC-flasher and the desired module you can buy here. Цитата
Colt_4G15T Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 Ok, I'm trying to read it next days. Pin 121-K-line must be OBD 7 136-boot must be OBD 11 (reflash connector) 77,82 must be OBD 16 (power 12V) 93 must be OBD 4 Is that right?? Цитата
Bruce Willis Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 What license do you have? Number of kye? Цитата
Colt_4G15T Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 I do not have any licence Цитата
СаняЖД Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 you bought a usb-dongle(key) from MMC-flasher here ? Цитата
Colt_4G15T Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 No! But I'm going to buy module 2 dongle otherwise I can't write back to ecu.. Цитата
СаняЖД Опубликовано 4 Марта 2014 Жалоба Опубликовано 4 Марта 2014 Ok. Today will explain how to do it. Цитата
