Today
prosper427 подписался на ECU pin assignments
ECU pin assignments
Need ECU pin assignments to connect this ECU on the bench. Make: Isuzu Engine: 4HK1-TC Year: 2014 Model: NPR Transmission: automatic ECU: Denso License: 15055
transtron 4jj1
transtron 4jj1
Здравствуйте, пока нет
36M Denso SH705x+eeprom
1М MH720x, MH8206, MH8305
Subaru Forester SH ищу сток
