Опубликовано 25 Апреля 2018%d л comment_22503 Модуль предназначен для обновления ЭБУ моторных , пока только CAN их версии. Так же модуль поддерживает чтение/удаление ошибок [22:39:30] ECU info(ECM Update(.frf/.sgo) CAN) Module: Module 61 VAG ECM Update(.frf/.sgo) 10.0(002) License: 1 [Adapter name] Tactrix Inc. - OpenPort 2.0 J2534 ISO/CAN/VPW/PWM [Firmware version] 1.16.4769 [Dll version] 1.01.4247 Apr 18 2014 16:14:11 Battery: 12.265V [22:39:32] VW/Audi part number: 8K0907551D [22:39:32] Software version: 0003 [22:39:32] Hardware part number: 8K0907551A [22:39:32] Hardware version: X07 [22:39:32] ASAM/ODX file identification: EV_ECM30TFS0218K0907551D [22:39:32] ASAM/ODX file version: 001003 [22:39:32] VIN: WAUDGAFL9BA084172 [22:39:32] FAZIT-identification: SME-RBG05.11.1003931158 [22:39:32] CVN: BC966676 [22:39:32] Coding: 01 04 00 0A 18 0F 01 28 35 2E [22:39:32] System description: 3.0T SIMOS84 [22:39:32] Engine code: CCBA [22:39:32] Protocol: UDS/FRF [22:39:34] Open FRF/SGO(ECM Update(.frf/.sgo) CAN) Module: Module 61 VAG ECM Update(.frf/.sgo) 10.0(002) License: 1 File selected: С:\Auto\FL_8K0907551D__0003.frf Loaded: EMEM_8K0907551D_0003.DB_1ERASE EMEM_8K0907551D_0003.DB_1 EMEM_8K0907551D_0003.DB_2ERASE EMEM_8K0907551D_0003.DB_2 EMEM_8K0907551D_0003.DB_3ERASE EMEM_8K0907551D_0003.DB_3 [22:39:40] Write(ECM Update(.frf/.sgo) CAN) Module: Module 61 VAG ECM Update(.frf/.sgo) 10.0(002) License: 1 [Adapter name] Tactrix Inc. - OpenPort 2.0 J2534 ISO/CAN/VPW/PWM [Firmware version] 1.16.4769 [Dll version] 1.01.4247 Apr 18 2014 16:14:11 Battery: 12.417V [22:39:43] Writing ROM [22:39:43] Execution EMEM_8K0907551D_0003.DB_1ERASE... [22:39:49] Execution EMEM_8K0907551D_0003.DB_1... [22:40:00] Execution EMEM_8K0907551D_0003.DB_2ERASE... [22:40:11] Execution EMEM_8K0907551D_0003.DB_2... [22:43:18] Execution EMEM_8K0907551D_0003.DB_3ERASE... [22:43:21] Execution EMEM_8K0907551D_0003.DB_3... [22:43:59] Writing ROM OK Жалоба
Опубликовано 25 Апреля 2018%d л Автор comment_22504 Для чего это было сделано, модуль умеет обновлять любой моторный, не нужно ставить ODIS. И например в SIMOS'ах виртуально читаются только калибровки, а прошивка может быть старая, ее нужно обновить до той которая есть в наличии. Жалоба
Опубликовано 28 Апреля 2018%d л Автор comment_22515 Обновиться через Онлайн магазин, модуль бесплатный. Жалоба
Опубликовано 2 Июня 2018%d л comment_22665 Сборку обновляли через http://mmcflash.com.ru/?q=ru/catalog/47-modul-ford-usa Жалоба
Опубликовано 9 Ноября 2018%d л comment_23264 Возможен обратный процесс? Не обновить а наоборот понизить версию прошивки в пределах одного и того же софт. И возможна ли будет опция по пересчету CVN? Изменено 9 Ноября 2018%d л пользователем azazero Жалоба
Опубликовано 10 Ноября 2018%d л comment_23266 15 часов назад, azazero сказал: Возможен обратный процесс? Не обновить а наоборот понизить версию прошивки в пределах одного и того же софт. И возможна ли будет опция по пересчету CVN? Даунгрейд обычно возможен, если такая возможность разработчиками намеренно не исключена, как в случае с тем скандальным дизелем. Насчет подделки цвн не знаю, редко просят. В 61м модуле точно ее не будет, это просто модуль, записывающий содержимое frf/sgo, он не распаковывает и не расшифровывает прошивку. Жалоба
Опубликовано 17 Января 2019%d л comment_23532 Добрый день! Есть потребность в frf конвертер, может как вариант в виде модуля. Жалоба
Опубликовано 17 Января 2019%d л comment_23533 1 час назад, Serg1 сказал: Добрый день! Есть потребность в frf конвертер, может как вариант в виде модуля. Фрф конвертер на всё подряд тяжеловатая задача. Внутри .odx, в котором подготовленные для отправки устройству данные - сжатые и зашифрованные разными способами, в зависимости от устройства. Для каких именно блоков интересует? Жалоба
Опубликовано 1 Февраля 2019%d л comment_23585 еще раз для особо одаренных тоесть для меня имею ваг SIMOS PCR2.1 внутри 03l906023lp 9978 имею модфайл на базе 03l903023lp 8310 можно ли тупо этим подулем влить 03l906023lp8310.frf чтобы он у меня превратился с 03l906023lp 9978 в 03l903023lp 8310 спасибо Жалоба
Опубликовано 1 Февраля 2019%d л comment_23586 2 часа назад, blistograd сказал: чтобы он у меня превратился с 03l906023lp 9978 в 03l903023lp 8310 Блок может не принять этот даунгрейд, а может принять. При проверке первой сеции после записи может вернуть отрицательный статус и отказаться писать остальные. Как узнать это заранее неизвестно. Жалоба
Опубликовано 18 Февраля 2019%d л comment_23685 В 17.01.2019 в 16:42, f13nd сказал: Фрф конвертер на всё подряд тяжеловатая задача. Внутри .odx, в котором подготовленные для отправки устройству данные - сжатые и зашифрованные разными способами, в зависимости от устройства. Для каких именно блоков интересует? Понятно, а если для SIMOS PCR2.1 чтобы без разблокировки можно было? Жалоба
Опубликовано 18 Февраля 2019%d л comment_23687 2 часа назад, Serg1 сказал: Понятно, а если для SIMOS PCR2.1 чтобы без разблокировки можно было? Не понял вопрос. PCR2.1 61й модуль и так пишет без разблокировки, потому что только стоки. Разблокировка нужна чтобы механизм проверки цифровой подписи обойти. Жалоба
Опубликовано 25 Февраля 2019%d л comment_23724 Hello, Some one tried this module for upgrade MED17.5.5 ECU in 2013 A3 8P 1.4tfsi? It is purely can based, not UDS like 8K in the example of Bruce Willis. I tried it, but with no success. When I press write button I can get in the window messages until DLL version and nothing else after that. Buttons on the top of the program disappear, something happens, because I get on the FIS error message from brakes, but nothing after that. I leave it for 10 minutes like this and nothing! I can press X and close the program any time after I start writing sequence, but nothing was updated. Can I take some log of this, so I can help you debug this. Sorry that I write to you all in English, but I can only understand 90% of Russian language, but can't speak it Спасибо, Христо Жалоба
Опубликовано 2 Марта 2019%d л comment_23772 В 25.02.2019 в 22:06, Христо Атанасов сказал: Hello, Some one tried this module for upgrade MED17.5.5 ECU in 2013 A3 8P 1.4tfsi? It is purely can based, not UDS... If not don't try it!!! At least in near future After sending logs to Bruce Willis, and fix from his side something happened.. writing started to do something, but cant finish flawlessly. At the end - car is dead! fans running constantly, ECU respond to ECU ID, respond also in VCDS, but I noticed something strange. ECU starts to appear like UDS ECU in VCDS (no measuring block like on CAN cars, instead Adv. Meas. Values like on UDS cars). Any idea how to restore? Of course I don't have full read, because ECU wasn't been opened until now, so now I was trying only to update software version on this car (writing stock .sgo car). I don't have ODIS, so I can't try to restore with it and I'm not sure I can restore with it. Regards, Chris Жалоба
Опубликовано 3 Марта 2019%d л Автор comment_23774 When you have a problem, please send all info in support. Don't need write in the forum. We always help you. Жалоба
Опубликовано 3 Марта 2019%d л comment_23775 It is not because of lack of support - it is quite opposite I think your support is GREAT! And I'll strongly recommend your product because of this point. I think forums are for something else - not exactly solving problems, that support can do but sharing experience. And I highly believe in "wisdom of the crowd". I believe someone can suggest something in some cases something different than others, and some time this helps a lot! Жалоба
Опубликовано 23 Мая 2019%d л comment_24062 Can I use this module to update simos 12 ecu on 2012 1.8tfsi 170hp audi a4? I want to update from 8K0906264 0008 to 8K0906264 0009. I have .frf file. Жалоба
Опубликовано 24 Мая 2019%d л comment_24069 Всем здравствуйте.Подскажите пожалуйста данный модуль запишит на столе файл frf или только на автомобиле?Спасибо. Жалоба
Опубликовано 24 Мая 2019%d л Автор comment_24070 Только на автомобиле , без иммобилайзера VAG группа не шьётся по обд протоколу. Жалоба
