Опубликовано 16 Мая 2018%d л comment_22582 when a car check engine light refused to appear,does is mean the ecm is completely dead or can it be flashed with firmware? Жалоба
Опубликовано 16 Мая 2018%d л comment_22585 You can always try to overwrite a block, but the block will answer you or not depends on many factors. Жалоба
