Ezenigbo Опубликовано 16 Мая 2018 Жалоба Опубликовано 16 Мая 2018 when a car check engine light refused to appear,does is mean the ecm is completely dead or can it be flashed with firmware? Цитата
mastercson Опубликовано 16 Мая 2018 Жалоба Опубликовано 16 Мая 2018 You can always try to overwrite a block, but the block will answer you or not depends on many factors. Цитата
