mitsubishi mirage immo off
hi,
please need immo off solution for mitsubishi mirage 2013
ecu
1860C142
E6T80078
processor MH8115F
eprom 25A16
i read ecu file with mmcflasher
thanks
mh8115f 1860C142.rar
please can module 63 make immo off for this ecu
am new to mmcflasher i bought purposely for mitsubishi ecu
will order module 63
thanks
В 05.02.2019 в 21:13, Philipcoin сказал:
Send me report file with 'ecu info' (works without activation) for that ecu.
p.s.: report files location is c:\Users\<username>\Documents\MMC flasher\
18 часов назад, f13nd сказал:
Here is your options list (for your vin + diagversion, values may be another)
have order for module 63
will test this option and give feedback
thanks
1 час назад, Philipcoin сказал:
hi
please here,
can you check if am doing the right thing
thanks
mirage coding.rar
same vin, but wrong skey (another diagversion?). give me report file with 'read coding'
helo,
i did few test since is my first using this module so i sent you test log
thanks
2019.02.07_08.57.26_ECU Coding CAN_ECU info.htm.gz
2019.02.07_09.06.50_ETACS Coding CAN_Write with edit.htm.gz
2019.02.07_08.57.31_ECU Coding CAN_Read coding.htm.gz
21 час назад, f13nd сказал:
sorry, last version was not uploaded to server. 63(010), http://mmc.ru.com/updates/10A6BB22A3EAC9786C88384E20.exe
read codings again.
hi
please read coding and send logs right
thanks
2 hours ago, Philipcoin said:
hi
thanks
here are log files
new update not show details most is unavailable
please check
thanks
ML32A3HJ4EH013592_1860C142 new.xml
2019.02.08_11.03.27_ECU Coding CAN_Read coding.htm
42 минуты назад, Philipcoin сказал:
ident on which these parameters depend is not available:
Write: 00 00 07 E0 21 52
Read: 00 00 07 E8 7F 21 12
fixed. 63(011) http://mmc.ru.com/updates/10A6BB22A3EAC9786C88384E20.exe
You can use last .xml
4 hours ago, Philipcoin said:
hi
thanks
here are log files
please check
thanks
here ecu logs
etacs coding not working you can check most unavailable
thanks 2019.02.08_04.57.40_ECU Coding CAN_Read coding.htm
ML32A3HJ4EH013592_1860C142 NEW UP.xml
will test and report
thanks
i test your solution still not working
can your software make immo off
new update write coding to ecu
new update not commnicate etacs
2019.02.08_10.48.58_ECU Coding CAN_Write with edit.htm
2019.02.08_10.47.54_ECU Coding CAN_Read coding.htm
19 минут назад, Philipcoin сказал:
you need to disable immobilizer ("not present") in ecu and etacs
20 минут назад, Philipcoin сказал:
give me report with no communication with etacs
15 минут назад, Philipcoin сказал:
please here is logs for etacs
2019.02.08_10.50.02_ETACS Coding CAN_Read coding.htm
just no response, check connection
Write: 00 00 07 AA 1A 87
Read:
Write: 00 00 07 A0 1A 87
Read:
Write: 00 00 06 20 1A 87
Read:
[10:50:02] Error: no response from ECU. Check contacts and additional devices on bus, such as anti-theft alarm system., code: 0000
Will check connections on Etacs and give feedback
thanks
