Опубликовано 15 Марта 2020%d л comment_25146 Is it possible to read/write FORD SID208 SID209 SID211 in OBD? or must it be unlocked in boot or bench? is a solution in planning for SID212EVO? thanks Жалоба
Опубликовано 16 Марта 2020%d л comment_25150 SID208 only with unlock SID21 need ecu to add, if you have it - send it, module free for you. Жалоба
Опубликовано 16 Марта 2020%d л Автор comment_25152 A3C02351200 Coniinental SID212EVO i would have here. How long would you need for this? (i ask because it is customer vehicle.) Жалоба
