Опубликовано 26 Июня 2020%d л comment_25410 I have a 1998 Mitsubishi RVR that has an ECU with two 7202f processors one for ECU and one for TCU. I have successfully read the engine rom and then went to read the transmission rom but with no luck. i have moved the boot pin from pin 26 to pin 27 on the Datalink connector as outlined here:https://www.evoscan.com/technical-vehicle-manuals/12-mitsubishi-diagnostics But I'm getting the below error in Ecuflash and I'm wondering if i would be able to dump the TCU rom with MMCflash if I was to purchase it? sending init sequence 2 got 0x10 response instead of 0x11 sending init sequence 3 entering bootloader sending kernel size (2029) error sending kernel size interface close Жалоба
