mototroonik Опубликовано 7 Апреля 2021 Жалоба Опубликовано 7 Апреля 2021 Hello, Has anyone ever used transtron module 70, for flashing Case excavator with 4HK1 over OBD? I managed to read without any problems, but I have some people telling me that writing tends to fail, which is why people do them with KTAG in BDM. Any truth behind that or just false stories? Since I dont have KTAG at my disposal I would rather not take the risk, if the mmc obd solution is still rather in beta development stage.
Bruce Willis Опубликовано 7 Апреля 2021 Жалоба Опубликовано 7 Апреля 2021 Hello , you can have problem only if you write BAD EDIT SOFTWARE. In other cases all be ok! 1
mototroonik Опубликовано 7 Апреля 2021 Автор Жалоба Опубликовано 7 Апреля 2021 Thank you for such short notice.
brookhaven66 Опубликовано 16 Августа 2021 Жалоба Опубликовано 16 Августа 2021 looking for ecu pinout transtron M3SC for isuzu 4HK1 it has 60 pin connector and 94 pin connector. Thanks
brookhaven66 Опубликовано 16 Августа 2021 Жалоба Опубликовано 16 Августа 2021 i asked support few days back,support tell me to ask "Bruce Willis' in forum. It's exact same ecu as "4KH1 safe" thread I guess i can try support again
Bruce Willis Опубликовано 16 Августа 2021 Жалоба Опубликовано 16 Августа 2021 3 часа назад, brookhaven66 сказал: i asked support few days back,support tell me to ask "Bruce Willis' in forum. It's exact same ecu as "4KH1 safe" thread I guess i can try support again 5 days back you don't send ECU photo and i gave link how need to ask pinoout, i gave you th same link as in my last post on this theatred. And i don't write you to ask any body, just link how need ask pinout in support, with ecu photo and connector photo. Don't need write here, write to suport 1 good request and wait answer.
Keogh Опубликовано 24 Августа 2021 Жалоба Опубликовано 24 Августа 2021 В 07.04.2021 в 14:26, Bruce Willis сказал: Hello , you can have problem only if you write BAD EDIT SOFTWARE. In other cases all be ok! Hello mid it possible to recover if bad edit software was flashed and now no coms ?
Bruce Willis Опубликовано 25 Августа 2021 Жалоба Опубликовано 25 Августа 2021 Hello yes, but only with Ktag, dim sport, piasinin etc
Keogh Опубликовано 25 Августа 2021 Жалоба Опубликовано 25 Августа 2021 Hi I tried with ktag, trasdata and no good can’t get coms, I tried read procedure and write procedure and can’t get id on ktag or trasdata please advise thanks
Bruce Willis Опубликовано 26 Августа 2021 Жалоба Опубликовано 26 Августа 2021 We support only mmcflash, advise you need get from support ktag and trasdata
brookhaven66 Опубликовано 27 Августа 2021 Жалоба Опубликовано 27 Августа 2021 my mmcflash worked great reading and writing this transtron without open ecu,hopefully you haven't damaged ecu already 1
buytuning Опубликовано 27 Августа 2021 Жалоба Опубликовано 27 Августа 2021 Some examples of tools I've made very successful case cx300c-350-370 transtron ecu sh7059 reading 1h 50 min write 30 min isuzu novo 4hk1e6 transtron sh72544 1h 30 min reading write 10 min isuzu dmax 4jk1 reading 1h 30 min write 10 min 1
markus.brunner3 Опубликовано 29 Октября 2021 Жалоба Опубликовано 29 Октября 2021 who has a pin out ( bench) of the ECU. have a hitachi excavator do not know where to connect obd.
Bruce Willis Опубликовано 29 Октября 2021 Жалоба Опубликовано 29 Октября 2021 https://mmcflash.ru/forum/topic/1811-request-ecu-pinout/
Rukmal Опубликовано 5 Ноября 2021 Жалоба Опубликовано 5 Ноября 2021 Isuzu transtron M3SC Support pin out for read write ecu via CAN BUS on table. this pin out 100% with mmcflasher i have tested my hand Ground - Black 12V / 24V - Red Blue - CAN L Yellow - CAN H 1
eljisu Опубликовано 25 Января 2022 Жалоба Опубликовано 25 Января 2022 Today I tried to write the same ecu in eobd, it has been read perfectly, but when I went to write the mod file, it told me correct checksum and the writing has finished, it showed write ok, but the machine does not start, now I can not communicate with the ecu in eobd, what has happened? How can I recover the ecu? 1
Rukmal Опубликовано 25 Января 2022 Жалоба Опубликовано 25 Января 2022 29 минут назад, eljisu сказал: Today I tried to write the same ecu in eobd, it has been read perfectly, but when I went to write the mod file, it told me correct checksum and the writing has finished, it showed write ok, but the machine does not start, now I can not communicate with the ecu in eobd, what has happened? How can I recover the ecu? Hello I can Help you. please tell me more details. what is engine model? what is ecu? post some ecu photo too i can help you. first at all write ori file back. and check ecu communication ok or not.
eljisu Опубликовано 25 Января 2022 Жалоба Опубликовано 25 Января 2022 Hello friend, the ecu is the following, it is a case cx300c machine, now I cannot write the ori file, I do not have communication with the ecu, what can I do? Do you need more info? Thanks
Bruce Willis Опубликовано 26 Января 2022 Жалоба Опубликовано 26 Января 2022 22 часа назад, eljisu сказал: Today I tried to write the same ecu in eobd, it has been read perfectly, but when I went to write the mod file, it told me correct checksum and the writing has finished, it showed write ok, but the machine does not start, now I can not communicate with the ecu in eobd, what has happened? How can I recover the ecu? You write bad bin file. Now recovery only piasini, k-tag etc
eljisu Опубликовано 5 Февраля 2022 Жалоба Опубликовано 5 Февраля 2022 I have to admit that the mod file was wrong, I wrote with transdata the ori file read with mmcflah in eobd and the ecu came back to life, later I re-wrote a new mod file with mmcflah in eobd and the write was correct, mmcflah works on this ecu correctly 2
eljisu Опубликовано 8 Марта 2022 Жалоба Опубликовано 8 Марта 2022 I report a new news, today I have written modified file in case cx300d in the obd diagnostic connector, I have read and written and everything worked perfectly, 1
SUNDOWNER TRUCK Опубликовано 19 Мая Жалоба Опубликовано 19 Мая (изменено) Good day i have a 4hj1 isuzu transtron ecm and need pinout for mmc read see attached pics thanks Изменено 19 Мая пользователем SUNDOWNER TRUCK
Создать аккаунт
Есть аккаунт? Войти.
Войти
