afulmer29 Опубликовано 18 Апреля Жалоба Опубликовано 18 Апреля I first tried to read through 16-pin OBDII but i cannot get it to read. Its a 2018 Isuzu NPR with 3 plug denso GEN2. I have Module 69(087) and idk if i have pinout wrong but i cannot get it to read. So i pulled ECU and now have it on bench. im unsure if i have it pinned correctly, but i can get it to see module with device tester and also identify in mmc flash with a different module number. It also it asks to key off with master switch but i do not have a switch or know which pin is for key off/on. any advice would be great or proper pinout possibly. Also maybe i need special harness? i am also using USB link 3 which supports J2534. I can get it read ecm info under the Denso SH7059 (Module 82 section) but i know 1536k is not correct size for this ecu. Here is what it identifies under Denso SH7059 CAN (Which is wrong): [Adapter name] NEXIQ Technologies - USB-Link 3 USB [Firmware version] 0.017654 [Dll version] 3.2.1.6 [18:13:57] Software version: 0 [18:13:58] System Supplier ID/ECU Hardware Number: DEN875566 [18:13:59] Programming Date: FFFFFFFF [18:14:00] Module 03 Part Number: 3 [18:14:00] Module 04 Part Number: 4 [18:14:00] Module 05 Part Number: 5 [18:14:00] Module 06 Part Number: 6 [18:14:01] Software Part Number: 98392468 [18:14:01] Hardware Part Number: 98392463 [18:14:01] VIN: JALC4W163J7K01096 Here is when i try to read with correct module 82 [Adapter name] NEXIQ Technologies - USB-Link 3 USB [Firmware version] 0.017654 [Dll version] 3.2.1.6 [18:05:25] Error: no response from ECU. Check contacts and additional devices on bus, such as anti-theft alarm system., code: 0000 Any ideas on what im doing wrong? Possibly get correct pinout, or what adapter is needed? Thank you Цитата
Bruce Willis Опубликовано 18 Апреля Жалоба Опубликовано 18 Апреля Hi module 69 work only on table and need any other J2534 , not nexiq https://mmcflash.ru/forum/topic/1811-request-ecu-pinout/ Цитата
