Опубликовано 21 АпреляАпр 21 comment_32012 Good Afternoon, I am seeking assistance with an issue related to Code P161F. I have purchased MMC Flash and would like to know which module is required for this task. Additionally, I need guidance on the correct pinout to use. The chipset in question is SH72533. Thank you in advance for your support. Жалоба
Опубликовано 21 АпреляАпр 21 comment_32015 Hi 103 module + 130usdt renew for renew after you will have our module and read fullflash + eeprom https://mmcflash.eu/manual-order Жалоба
Опубликовано 23 АпреляАпр 23 Автор comment_32031 Thank you for your help, Do i read via OBD or pinout the box? Regards Жалоба
Опубликовано 28 АпреляАпр 28 Автор comment_32069 Hello, Please can you confirm which module i need as there is 3 versions of the 103 module? The 400$, 67$ Or 133$ Regards Mike 103 Module Master, Nissan Hitachi SH72533/SH72543 400$ 103 Module Slave, Nissan Hitachi SH72533/SH72543 67$ 103 Module, Nissan Hitachi SH72533/SH72543 133$ Жалоба
Опубликовано 30 АпреляАпр 30 Автор comment_32085 Good day, I just wanted to share an update: the solution provided by mmcflash is absolutely correct and works perfectly. Thank you very much for the support. Outstanding experience - A+++ Жалоба
