Mike prater Опубликовано 21 Апреля Жалоба Опубликовано 21 Апреля Good Afternoon, I am seeking assistance with an issue related to Code P161F. I have purchased MMC Flash and would like to know which module is required for this task. Additionally, I need guidance on the correct pinout to use. The chipset in question is SH72533. Thank you in advance for your support. Цитата
Bruce Willis Опубликовано %s в %s Жалоба Опубликовано %s в %s Hi 103 module + 130usdt renew for renew after you will have our module and read fullflash + eeprom https://mmcflash.eu/manual-order 1 Цитата
Mike prater Опубликовано %s в %s Автор Жалоба Опубликовано %s в %s Thank you for your help, Do i read via OBD or pinout the box? Regards Цитата
