Опубликовано 16 ИюняИюн 16 comment_32464 For the MMC Flash loader to function correctly on recent versions of Windows, you need to add it to the Defender exclusions rather than disabling Defender itself. To do this, go to the "Update and Security" in the system settings. Next, go to the "Windows Security" Go to Virus & Threat Protection In the virus & threat protection settings, go to Manage settings Scroll down to Exceptions and click "Add or remove exceptions" Add the folder with the installed program and the mmcflasher.exe file to the exceptions After adding, you need to reinstall (update) the program. Жалоба
Опубликовано 54 минуты назад%d мин comment_33365 В 16.06.2026 в 18:25, strel05 сказал:For the MMC Flash loader to function correctly on recent versions of Windows, you need to add it to the Defender exclusions rather than disabling Defender itself.To do this, go to the "Update and Security" in the system settings. Next, go to the "Windows Security" Go to Virus & Threat Protection In the virus & threat protection settings, go to Manage settings Scroll down to Exceptions and click "Add or remove exceptions" Add the folder with the installed program and the mmcflasher.exe file to the exceptions After adding, you need to reinstall (update) the program. Жалоба
