oltmann Опубликовано 5 Августа 2011 Жалоба Опубликовано 5 Августа 2011 Hello, Does MMCFlash support all Mazda/Renesas 7055 and 7058 ECUs? I'm particularly interested in the 2006 Mazda 6 3.0l. Also, the 2009+ RX-8. It is just a hobby, but I have spent some time learning to disassemble and map these ROMS. So, editing and tuning isn't too hard for me, but flashing Mazda ECUs other than MZR isn't talked about much, at least in the US. Thanks! Цитата
Bruce Willis Опубликовано 5 Августа 2011 Жалоба Опубликовано 5 Августа 2011 At present supports not everything, but the update prepares. 2006 Mazdas 6 3.0l and 2009 + RX-8 are necessary for photo ECU. Цитата
alphamusic Опубликовано 12 Декабря 2011 Жалоба Опубликовано 12 Декабря 2011 hi Bruce... we are new customer of you with mazda plugin! used piasini for a lot of time for flashing.. did you have any mps 3 stock file which you read with your tool... until now i dont have a car here.. thanks a lot Chris Anyway what is l8test version of mmcflash ? Цитата
Bruce Willis Опубликовано 13 Декабря 2011 Жалоба Опубликовано 13 Декабря 2011 I don't have this car, but i think no problem with MMC - read it and flash. 8 module test it is Ford Focus 2 with 1.6L engine. You can read, but you did't write flash. Цитата
