4g63t MR988925 MH8305F READING
HI
PLEASE HELP READING THIS ECU FLASH,MMC KEEP TELLING ME  Init ERROR,is there any special connection to read this ecu,please if you have a picture of connection on table.
If a car, the
connect the device to the OBD-II connector and additional connectors .....
Lancer cars?
post-1269-0-33804300-1423632928_thumb.jp
If on the table, then perhaps this:
pin 13,26 "-12V"
pin 12,25,80,82 "+ 12V"
pin 62 "K-Line"
pin 79 "Resolution of programming"
post-1269-0-08200700-1423633679_thumb.jp
thanks for reply,but the ecu i have is different,it have 4 connectors ,3 rows each,its ecu+tcu.
please note that this ecu maybe with immobilizer,may be this is why it cant read.attached pics of ecu.
post-2091-0-59724300-1423657768_thumb.jp
post-2091-0-78964400-1423657813_thumb.jp
I didnt use boot,i thought its used for only writing,if its used for reading,please help how to connect on table
yes ,full Mitsubishi authorization ,and open port 2,i didnt use boot pin for reading.please help identifiying boot pin for this ecu on table.and how to connect..
it didnt work ,i cant read this ecu,but i can read dtc and ecu information when i connect the same obd cable.on g-scan diagnostic,i connected boot from pin12 of obd,tried internal boot and external but no luck,i used this new tactrix on can bus and it worked fine on denso and honda,but i think its damaged on k-line,i noticed that when mmc communicates  with  ecu on k-lin,there is no activity.....13 volt should randomly go to 0 or 1 volts,but that never happen even .2 volts....never.
please inform me how to make sure that my tactrix  k-line is working or not.if there is away.
thanks for all
thanks to all,the customer couldn't wait, i ordered new mux,ill keep you informed when mux is in my hands,thanks all. i hope admin give me authorization to see pinout section.
