Гость DeeGraf Опубликовано 1 Ноября 2011 Жалоба Опубликовано 1 Ноября 2011 Hi! I've got a MD362115? I use the USB-Dongle from EVOScan for MH7201F's and a Openport 1.3u. As Software for Reading out i use MMCFlasher. I can read out my Ecu, but not Write. I got always identity Errors. That i can read out my ECU i have to START my engine, put in the cable and then i got only one chance to read out. All following operations don't work. Only the first operation after put in the cable works, after i get Identity Errors at all operations. Only with ignition on i get Identity Errors from begining. Please help me. Engine: 4g93 GDI ECU ID: E53F HW: MD362115 SW: EM1325 CPU: MH7201F Thanks in advace 1 Цитата
Bruce Willis Опубликовано 1 Ноября 2011 Жалоба Опубликовано 1 Ноября 2011 Please be registered here at a forum. You can read flash, but can't write? Make a program screen when it gives out an error. This module was tested with interface Open port 2.0. 1 Цитата
DeeGraf Опубликовано 1 Ноября 2011 Жалоба Опубликовано 1 Ноября 2011 I've got a OP 1.3U. Evoscan Said it's best for MH7201F. A Screen isn't very usefull. As i said. Always the same Error. Identity Error. Thanks for very fast answer!! Цитата
Bruce Willis Опубликовано 2 Ноября 2011 Жалоба Опубликовано 2 Ноября 2011 At me unfortunately isn't present at present Open port 1.3. Specify at Evoscan, from it bought many such modules, whether there are those who use such interface. I think there is no pressure for rewriting on boot pin. Цитата
Bruce Willis Опубликовано 2 Ноября 2011 Жалоба Опубликовано 2 Ноября 2011 You can try to write it with open port 1.3 use at settings "use manual boot pin". Software will tell you, when you must plug +16 or +18V on boot pin. If not work, then by OP 2.0. 1 Цитата
DeeGraf Опубликовано 2 Ноября 2011 Жалоба Опубликовано 2 Ноября 2011 Ok i Will try it like this. Sorry but.. which one is the Boot pin? Is it one on the obd Connector? Thanks Very much! Цитата
Bruce Willis Опубликовано 3 Ноября 2011 Жалоба Опубликовано 3 Ноября 2011 Boot pin is the additional pin on the open port 1.3 1 Цитата
DeeGraf Опубликовано 5 Ноября 2011 Жалоба Опубликовано 5 Ноября 2011 Writing works with Manual Boot pin Mode. But it stops everytime after +- 10%. I guess the ecu falls into the protect mode? What should i do now. Цитата
DeeGraf Опубликовано 6 Ноября 2011 Жалоба Опубликовано 6 Ноября 2011 Im Trying to create a xml File. Could Somebody Help me? Ragards Цитата
Bruce Willis Опубликовано 6 Ноября 2011 Жалоба Опубликовано 6 Ноября 2011 MMCflash don't need xml. 1 Цитата
DeeGraf Опубликовано 6 Ноября 2011 Жалоба Опубликовано 6 Ноября 2011 Yes but for edit my maps i need a xml file. And i need to find the maps in the ROM Цитата
DeeGraf Опубликовано 7 Ноября 2011 Жалоба Опубликовано 7 Ноября 2011 Here's my Rom I Used Analyzer.exe for finding Maps. I Found some of the maps. High and low Octane Fuel i'm 99% Sure that it is True. For those i only not found the RPM and Load Scale. Other maps i dont know what is what, i added them into the konck filter maps that you can find the Offsets. Do you have any idea why MMCFlasher stops wrtitng after a few seconds? approximately 20 sec then the bar stands still. Regards Цитата
DeeGraf Опубликовано 10 Ноября 2011 Жалоба Опубликовано 10 Ноября 2011 Other question, where can i get software updates for the MMCFlasher software? I'm not sure if my version is the newest. I bought it from evosan. But the site is ipdating very slow and there are no updates for mmcflash. What about the ROM. Can you do anything with, or do you need more files or anything? I'd like to help you if i can. Regards Rom n XML.zipFetching info... 1 Цитата
DeeGraf Опубликовано 18 Ноября 2011 Жалоба Опубликовано 18 Ноября 2011 Hi! I just wanted to know how you move forward? Can you give me the newest version of MMCFlasher please? I want to make sure that the error does not come from the software. I have read on the evoscan page that a new version is available from MMCfalsher. However, the page wasnt renewed since looong time, and this is why no update is available on the site. Do you need anything for easyer create the XML? Like Engine model or anything? Regards! 1 Цитата
Bruce Willis Опубликовано 24 Ноября 2011 Жалоба Опубликовано 24 Ноября 2011 В 18.11.2011 в 17:50, DeeGraf сказал: Can you give me the newest version of MMCFlasher please? I want to make sure that the error does not come from the software. Give me email and license number mmcflash 1 Цитата
DeeGraf Опубликовано 3 Декабря 2011 Жалоба Опубликовано 3 Декабря 2011 Just bought OP2! When i've got it, i try to write, read out my ecu new and post it. What about the XML? Any news? Regards Цитата
Bruce Willis Опубликовано 3 Декабря 2011 Жалоба Опубликовано 3 Декабря 2011 Don't forget to correct the negative opinion http://forums.openecu.org/viewtopic.php?f=2&t=5192&p=25809#p25809 1 Цитата
DeeGraf Опубликовано 3 Декабря 2011 Жалоба Опубликовано 3 Декабря 2011 В 03.12.2011 в 14:20, Bruce Willis сказал: Don't forget to correct the negative opinion http://forums.openecu.org/viewtopic.php?f=2&t=5192&p=25809#p25809 Done, Sorry! Цитата
Bartek Опубликовано 6 Декабря 2011 Жалоба Опубликовано 6 Декабря 2011 I have similar problem, but I can't even read ECU - Identity errors MMCFlash + OP2 cable Engine: 4g93 GDI HW: MD351866 E2T68374 CPU: MH7201F Pics: http://www.evoscan.com/helpdesk/download_attachment.php?att_id=167&track=JQ6JU4VYSD http://www.evoscan.com/helpdesk/download_attachment.php?att_id=168&track=JQ6JU4VYSD Any suggestions? Цитата
Bruce Willis Опубликовано 6 Декабря 2011 Жалоба Опубликовано 6 Декабря 2011 Do you connect boot pin? Цитата
Bartek Опубликовано 6 Декабря 2011 Жалоба Опубликовано 6 Декабря 2011 Yes of course My OP2 cable works perfect with Ecuflash and my Legnum VR-4 Цитата
Bruce Willis Опубликовано 6 Декабря 2011 Жалоба Опубликовано 6 Декабря 2011 Show a screen of the program, what point choose, when have received the program, what operating system? Цитата
