Can someone help me to create a definition XML for my ecu?
Make: Mitsubishi
Model: Space Star
Market: EDM
Year: 1998
Engine: 4g93 GDI
ECU ID: E53F
HW: MD362115
SW: EM1325
CPU: MH7201F
Interface: OpenPort 2 With MMCFlash Usb Module for MH7201F.
Thanks in advace!
--> Rom Posted on Page 1
  • Ответы 59
  • Просмотры 37k
  • MMCflash don't need xml.
  • In yours it is necessary open port 2.0, in case of Bartek when ECU it is not read and it is not written, it is necessary to remove immo physically with K line or to remove ECU.
  • Please be registered here at a forum. You can read flash, but can't write? Make a program screen when it gives out an error. This module was tested with interface Open port 2.0.
Initially yes, but with OP1.3U. Now i'll become an OP2.0 soon. Like you said, it should work to write my Ecu with OP2.0.
The only thing which i haven't got to change Map's in my ECU and flash it, is a XML file for my ECU. Please help me to
create a Valid definition XML for my Ecu. Without it i can't do anything usefull. I need XML to edit Map's in EcuFlash.
Here's my ROM again (Read out with OP1.3U n MMCFlash, Immo bytes should be on it!) Many Map's found with Analyzer.exe, but
Load and RPM Scale's not. The Area's which could be a Map (without knowing waht is what) I've saved und Kockbase Filters,
(to find the Offsets Later, when i know which table is what). Please help me to complete it.
Thanks in advance!
Best Regards
Rom n XML.zip
High & Low Octane Fuel and Ignition maps, EGR (Duty and State) i've got already. all the rest like open loop load, limits, fuel pressure, injector scaling, MAF etc. i'm searching for.
Stock Rom n XML Space Star 4g93 GDI.rar
  • 5 weeks later...
when you edit the value, such as rpm limiter. can you write back to the car successful with checksum on this ecu?
Yes it work fine with op 2.0
Update: Found Injector Scaling, Fuel Pressure Maps, Barometric Pressure Compensation, Idle Maps, Alternator Charge Map, Egr Timing Advance and Periphery Bits.
New Xml, n Rom posted.
Have a look
Searching injector Latency, Throttle percentage, and Maf Smoothing tables.
Many maps, i dont know what they are, saved in Misc
stock rom with xml em1325.rar
  • 5 years later...
I also have a Carisma with 4g93 GDI and I really need a definition file.
I know your posts are old, but are there any fully working xml files for that mh7201F GDI ecu?
Best regards
any new's?
В 22.04.2017 в 23:43, Red.Hit сказал:
Best regards
any new's?
does modul 1 contains xml files for this ecu?
