Hi!
I've got a MD362115?
I use the USB-Dongle from EVOScan for MH7201F's and a Openport 1.3u.
As Software for Reading out i use MMCFlasher. I can read out my Ecu, but not Write. I got always identity Errors.
That i can read out my ECU i have to START my engine, put in the cable and then i got only one chance to read out.
All following operations don't work. Only the first operation after put in the cable works, after i get Identity Errors
at all operations. Only with ignition on i get Identity Errors from begining.
Please help me.
Engine: 4g93 GDI
ECU ID: E53F
HW: MD362115
SW: EM1325
CPU: MH7201F
Thanks in advace
  • Ответы 59
  • Просмотры 35,5k
  • MMCflash don't need xml.
  • In yours it is necessary open port 2.0, in case of Bartek when ECU it is not read and it is not written, it is necessary to remove immo physically with K line or to remove ECU.
  • Please be registered here at a forum. You can read flash, but can't write? Make a program screen when it gives out an error. This module was tested with interface Open port 2.0.
I've got a OP 1.3U.
Evoscan Said it's best for MH7201F.
A Screen isn't very usefull.
As i said. Always the same Error.
Identity Error.
Thanks for very fast answer!!
At me unfortunately isn't present at present Open port 1.3. Specify at Evoscan, from it bought many such modules, whether there are those who use such interface. I think there is no pressure for rewriting on boot pin.
You can try to write it with open port 1.3 use at settings "use manual boot pin". Software will tell you, when you must plug +16 or +18V on boot pin. If not work, then by OP 2.0.
Ok i Will try it like this.
Sorry but.. which one is the Boot pin?
Is it one on the obd Connector?
Thanks Very much!
Writing works with Manual Boot pin Mode.
But it stops everytime after +- 10%.
I guess the ecu falls into the protect mode?
What should i do now.
Yes but for edit my maps i need a xml file.
And i need to find the maps in the ROM
Here's my Rom
I Used Analyzer.exe for finding Maps.
I Found some of the maps.
High and low Octane Fuel i'm 99% Sure that it is True.
For those i only not found the RPM and Load Scale.
Other maps i dont know what is what, i added them into the konck filter maps that you can find the
Offsets.
Do you have any idea why MMCFlasher stops wrtitng after a few seconds?
approximately 20 sec then the bar stands still.
Regards
Other question, where can i get software updates for the MMCFlasher software?
I'm not sure if my version is the newest. I bought it from evosan. But the
site is ipdating very slow and there are no updates for mmcflash.
What about the ROM. Can you do anything with, or do you need more files or anything?
I'd like to help you if i can.
Regards
Rom n XML.zip
Hi!
I just wanted to know how you move forward?
Can you give me the newest version of MMCFlasher please?
I want to make sure that the error does not come from the software.
I have read on the evoscan page that a new version is available from MMCfalsher.
However, the page wasnt renewed since looong time, and this is why no update is available on the site.
Do you need anything for easyer create the XML?
Like Engine model or anything?
Regards!
Just bought OP2! When i've got it, i try to write, read out my ecu new and post it.
What about the XML? Any news?
Regards
I have similar problem, but I can't even read ECU - Identity errors
MMCFlash + OP2 cable
Engine: 4g93 GDI
HW: MD351866 E2T68374
CPU: MH7201F
Pics: http://www.evoscan.com/helpdesk/download_attachment.php?att_id=167&track=JQ6JU4VYSD
http://www.evoscan.com/helpdesk/download_attachment.php?att_id=168&track=JQ6JU4VYSD
Any suggestions?
